SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
12.01.2008, 07:28 PM
It could be the area you are running it in. You might want to try running it in a few completely different areas. Also, are you sure there are no loose screws, no bad connections on the battery side? (you might have to yank on all of your solder joints to test this or replace your connectors if they are being reused from a previous setup) All power wires should be neatly twisted around each other for best results.
Area 52 Ranch Raceway
T.R.C.R.
