Originally Posted by MetalMan
Awesome! Great temps for sure. I'm glad it worked out.
Thanks Travis good thing you accepted this project
Originally Posted by sikeston34m
My suggestion from this point: Try some different battery combinations.
Maybe even try 5S or 6S. There's alot more untapped power in there. But it does look pretty quick just like you have it.
Thanks for the recognition. You guys make me feel like part of the family around here.
Thanks for the suggestion, actually the only reason I used A123 is that I have a 5S2P that I dont that much...So I reconfigured it to fit E-Revo (4S). The original plan is to use 4S Lipo (no money yet saving for the holiday and my little sister's wedding). Basically I just couldnt wait so I used A123
I'm thinking of getting RCM Lipo or PQ XP 6000mAh, though the RCM one might need to change the connectors
I am really thankful to you Sikes because of your Direct Drive to Diff I wouldnt have inspiration to begin with this setup.
Originally Posted by suicideneil
Turned out really well- no signs of cogging which is good news for sure. Only question I really have is whats the weight of the thing without batts? Must be pretty good since there is no tranny.
I really want to know the weight savings as well!
Thanks Neil, for the weight.......it's about 7-8lbs without battery. I dont have a smaller and more accurate scale but it showing around 3-3.5Kg
....this includes the UBEC and Sway Bars
