Not Too Bad.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Not Too Bad. - 12.03.2008, 09:05 AM
Well considering what you have in there, that is not too bad for weight. Half of that is probably batteries, and motor. All you can hope for is that it holds up until your MGM is returned from the factory. I would have some fun, but nurse it a little bit until you get close to having the MGM back, then run the hell out of the MMM. Then you will have a good comparison going between the two. You can also order those driveshaft pins either from UE, or RCAlloys. I am not sure if Mike has them or not here on RCM. It would not hurt to have a few spares on hand for future issues.
Originally Posted by jordan... View Post
i have got a mate whos a mechanic, so i should have easy access to a hydraulic press. It is a bit of a beast, 14lbs all loaded up. It sure did run well with the MMM V3, time will be the test now i guess, hopefully it doesn't crap out on me after a couple of weeks.
