Njord
12.03.2008, 12:42 PM
Interesting...A lot of machine/cc work in those parts! Looks like battery size is limited....?
The battery size is limited by the length. For most of the truggy Option Team BCP's this is 16 cm. For most buggy version's this is 12 cm, some 13 cm. We use the standard 10 cm lipo's (2200 and 2400 mAh cells) that can be build up till 6 - 8s each side of a buggy and 8-10s max each side of truggy. We use Kokam cells and also cells used for the welknown budget 'zippyline'. The 10 cm cells are used and sold a lot for heli and plain applications. Compared with the cells used for 1:10 car applications they are much cheaper when you compare on C rating and capacity.
The saddlepack shown at te pictures gives a 6s2p 4800 mAh combination and not 4400 mAh as I mentioned earlier. Runtime with 6s2p 4400 mAh zippy is approx 30-35 minutes on the 8-t in competition races. For my 8-t I have also a 6s 2p 8000 mAh zippy based lipo setup. Length of the packs is 15 cm. I will try this out coming weekend. I also hope to have somebody to make a vid of the running.
Runntime with a 6s2p 4800 mAh kokam lipo setup is 40 minutes at my 8ight buggy. With a 3600 mAh setup it is 25 minutes.
For the best handling of a buggy or truggy the weight needs to be centered to middle of the chassis. Also left/right and front/rear weight distribution is important, even far more important than the total weight of buggy or truggy. Also a low weight center is positive.
By that all setups with a accu (lipo or a123) on 1 side or 2 near the chassisguards far outside the center will give a handling (taking corners or jumping stable and fluently) that is less than of a nitroversion. The goal was to be at least on par with nitro, so a good and well balanced set up that can compete with the highest level setups of nitro. It is for that reason that we looked further than the lipo packs normally used. The result is on one aspect in fact better than all the original nitro setups. The center weight of all setups is lower than the original nitro setups what gives a better handling in taking corners.
Vittorio Moroni of Fioroni is a well known topspecialist in this work. He has build up the MP777 of Pavidis for the worlds 2006 and was his pitmate (both are good friends). In fact the MP777 was build up with 7076 alu parts and diffs made by Fioroni and not by Kyosho, only the plastic was original Kyosho. The buggy that won the worlds 2004 (by french driver Guillame Vray) was also build, prepared and supported by Vittorio.. For that I learn every day a lot from him. I made Vittorio enthousiast to work on brushless setup because I knew that he is one of the real topspecialists in the world that can realy make a top level and clean high competitive setup. I take care for the electric part of the setups of the OT BCP's.
I am also working on a start up of brushless 1:8 competition (Netherlands, Belgium and western part of Germany - Nord Rhein Westfahlen) and a brushless 'semi' pro team. Already contracted the NL and B champs 1:10 electro offroad for this team. The last Truggy race of this year was the first for Arthur Eehlen (B) and although he drove nitro because the OT BCP's was 'secret' project at that moment he directly took the victory....
I have added a picture of a GPS unit used at a run at a soccerfield. Gearing was 15/48. In a street run the 8-T did 87 km/h.
