bustitup
12.04.2008, 01:36 AM
Originally Posted by DRIFT_BUGGY View Post
It has to be run backwards, there is no motor out there with a shaft that long to run it around the correct way
lol..I found that out the hard way.....had the new motormount installed real nice used blue locktight and went to put the motor on and said.....somethings wrong.......but its not just a matter of turning the diff around...you have to take the diff apart to switch the drive cups and bearing around also because they use differant size bearings and the motormount will only work with a certain one
