Lee Estingoy
Castle's Odd Jobs Guy
Lee Estingoy's Avatar
12.05.2008, 10:54 AM
Originally Posted by Nephre View Post
Are they similar in amp draw to? Iīm getting one for my buggy soon but I havenīt decided if itīs going to be the 2650kv or the 2200kv. If I can cet better runtimes with the 2650kv Iīll probably get one of those
Watts is watts. :)
The 2200 is a slight bit more efficient than the 2650, it is a longer winding and that makes a small difference. Nothing that you'll really be able to measure as yielding longer runs.
The 2650 is intended for up to 4S. The main ways to increase run time are to
1. Go slower -- either through lower gearing, lower KV or lower voltage -- fewer cells.
2. Get bigger capacity cells.
Either of these motors will be a huge increase in what you are used to.
Hope this helps.
Lee
