12.05.2008, 01:12 PM
What would you use this in? They are the typical 70mm X 36mm dims (like Feigao), recommended to run in the 35-40krpm range (judging by their recommended voltage), and has a max efficiency of 85%. The one with the highest max power, Typhoon 600-32, is rated for 800w. For ~$83, it just seems like a 6-pole Feigao, nothing special according to specs alone.
