Semi Pro
Semi Pro's Avatar
12.05.2008, 01:53 PM
Originally Posted by teknorc View Post
Hello,
Strange, this is the first we've heard of this. Either way, one set screw will still work fine especially considering the tight fit (close tolerances) on the pinion gears. The clutch assembly is longer and heavier and only uses one set screw without any issues. I'm pretty sure the Neu and Medusa motors have slightly longer shafts (19mm-20mm).
dont you feal that extending the pinion out that far will put alot of stress on the front motor bearing?
and lead to failure?
