Thread: MMM v3 hiccup?
brushlessboy16
brushlessboy16's Avatar
12.05.2008, 05:34 PM
Does it do this in any direction relative to where you stand? It's probably radio related. Where is your Rx located relative to the ESC/motor/BEC(?)? It should be as far away as possible from those things to prevent glitching.
Im running spektrum dsm through my m8, it happens any direction- the rx is in the front of the truck, batt, motor and esc are wayy back
i dont know if it would catch interference from that
I had this happen with my Mamba Max- only mine went into full brake for a fraction of a second, but it happened at full throttle-- was kinda ugly.
I had this happen when i was running 75mhz, it would do that....
