SpeedAssault
SpeedAssault's Avatar
12.06.2008, 01:45 AM
Wow ! What a Great, informative, helpful & generous FORUM ! You guys are really great. Haven't experienced that much guidance before, the links are great. I believe I have found a place I fit in. I think that what these forums should be not the vague or the acronyms or make you search, ya know. It's really nice to have it all there. I look forward to helping in some way here also.
Originally Posted by TDC57 View Post
You’re more than welcome we all help out each other whenever we can..
your MM will do great on 4s no worries, you might want to think about adding a fan and doing mods to it later.. Just a thought..
Jordan is you man on the Center diffs too.. here's link to them if you want or watch Ebay they have some XT8 and 808 center on there now of sale
http://www.amainhobbies.com/product_...oducts_id/8633
You will also need some of these..
http://www.amainhobbies.com/product_...oducts_id/8629 or Ebay for a better buy..
Best of luck again should be a fun build..
Bye the way thanks for the compliments..
Very welcome
Yea, I really like that idea of tranny-diff idea instead of big emaxx tranny. I will work it in eventually. Thank u
For 4s I would recommend adding an extra Cap either the Novak HV 2700uf or similar.
You should also get an Ubec and the 5v fan is not a bad idea...
What do you recommend for 6 volt fans ? ?
going to use a Deminsion engineering BEC. I have Castle becs but I am using them in my Crawlers.
Humm , not sure just yet how to fit-add a Cap on the mamba, Castle tech said it will do well because they are so over built.
I'm stealing the MM out of my Latest Creation Full Throttle custom Super Crawler, build thread just added to my sig, it's got 6 watt 4 speaker MP3 stereo loaded in it complete with Real V8 engine sound.
Here's a sneak peek
My latest creation below
Console shifter turns car on
twin stick turns on stereo Amplifier
Sony MP3 with Tunes and Real V8 engine sound
18" wheel base 14" wide
Axial trans
Revo drive shafts
Losi aftershock Diffs, custom lockers
Hyper 8 shafts
Xtm hubs
custom SS axle tubes and Knuckles
1/4 Tube steel MIG welded Chassis
2wd, 4wd and DIG by Remote
HiTec 7955 front rear steering servos
Castle bec
Mamba max
Climbs great when tires are working, Moabs stink
ID:	6012   Click image for larger version
ID:	6013   Click image for larger version
