Ryu James
Ryu James's Avatar
12.07.2008, 01:05 PM
Originally Posted by shizzon View Post
so your going to be using mech brakes without and electriclutch? are you going to turn the brakes off on the MMM? or both? And did you just thread the components into the chassis, as there are none on the underside of the chassis. Carbon fiber is definately a wonder material as long as it is used correctly, and that chassis is sure to have all the strength you will need.
Very nice build!!
i will be using mechanical brakes and have the braking and drag completely off on the MMM. but i will use a longshank pinion instead of the elektriclutch as i like direct-drive better. this is how my current setup is on my 8t.
the reason there are no holes in the chassis is cuz i have not finished the build yet. i will post pics when completely finished but there will be countersunk screws in the chassis just like any other chassis.
Jammin SCRT10 Neu 1512 1y
