Nephre
Freediver
Nephre's Avatar
12.08.2008, 07:12 AM
Originally Posted by Lee Estingoy View Post
Watts is watts. :)
The 2200 is a slight bit more efficient than the 2650, it is a longer winding and that makes a small difference. Nothing that you'll really be able to measure as yielding longer runs.
The 2650 is intended for up to 4S. The main ways to increase run time are to
1. Go slower -- either through lower gearing, lower KV or lower voltage -- fewer cells.
2. Get bigger capacity cells.
Either of these motors will be a huge increase in what you are used to.
Hope this helps.
Lee
Even though I´m running a Neu 1515 1Y at the moment?
