12.08.2008, 06:20 PM
Originally Posted by JesseV View Post
...I dunno if i made a mistake by ordering the 70mm 2300kv for my brushless 1/8 buggy. Seems like the amp draw for 2200kv 80mm is about the same. But more power.
If you are pulling the same amount of amps for a given voltage, the power is the same.
The 70mm Medusa will do fine in a buggy. Many run the 60mm in a buggy with success - although i wouldn't unless it was really light (~7lbs).
