Originally Posted by _paralyzed_
lutach has a couple 4000wrms amps for sale. go big or go home
I'm trying to
downgrade my setup, not increase it!
Do you realize a true 4000w amp will draw 533A @ 12.5v (assuming 60% amp eff)?!?! Talk about a clear example of the benefits of higher voltage...
i just sent in an old crossfire 1000d 1000w amp for repair. this is old school class d technology, I ran this beast at 1/2 ohm pushing 4 kicker L7 12's in an s-10 it was sweet. now it pushes 4 infinity 12's in sealed boxes in my van
my buddy just bought a jl audio 1000/1 v2 from a pawn shop fo $300 This is a $700 amp. check your local pawnshop they usually have nice power tools too
Jl audio amps are a little low on the damping factor IIRC. They may work ok for mids/highs, but subs are a little more power hungry. But, I assume that is class D. Despite the high efficiency, I don't like the sound of class D amps, even on subs. I don't know what it is but I can hear the difference. Class AB for me baby!
Originally Posted by ikpthegame
I really don't need 4 m/h channels. I do have 4 speakers, but the rears are paralleled off the front, -2db, just for some rear fill. I like to keep my sound stage up front. No, a 4-channel is fine. 2 ch for the front, and 2 channel bridged for the sub.
Originally Posted by asheck
Brian,I was in the same boat looking for an amp for my truck.Good luck with your quest,I never could find what I wanted in the new school technology.I went with a old school Sony XM-4045 .It's the good gold series,when they were still actually made by Sony.I had 1 when I was doing stereo competitions,so I thought it was cool for me.BTW I had it paired with 4 SPL 12's,2 5.0 amps,good for 150.7 db in an Eagle Talon.The best thing was the little 45 watt amp pushed all my mids and highs and actually kept up with the bass.
My current setup 1x12" on 600w was measured at 140.1db, but wasn't really set up for SPL - just wanted to see what it would do. This in my current setup:
Trunk with cooling grate:
Same pic with false floor removed. You can also see where I stow my tire changing tools.
This is the small area out near the back (in pic 1 and 2). This is where all the connections are made. I can simply unhook everything within 20 seconds and pull the whole thing out if I want. Even with everything in, I can still get to my spare tire.
So far, hippie has an 4x50 MTX amp that sounds like it will work. Just sorting out the details. If that falls through, then
this is probably something I'll be looking at. I'd like to find something here from a fellow member, because I do have a few tradeable items.
