12.09.2008, 12:53 PM
I also wish there was a better, relatively inexpensive, diff setup. You can't change the grease to oil because the diffs leak (at the shafts and around the diff cover). So, it's either grease, or super thick oil, or locked. I'm sure a "real" diff could be done - look at the CRT.5. Either that, or come up with a better (aluminum) sealable case and use rubber seals on the shaft.
