Thread: 9XL headache
12.10.2008, 02:15 AM
just temp check the motor and esc often as you test it, a demaged motor usually feels weak and glitchy, especially off the line, and you are right about the airflow, it is important to have the cooling airflow, otherwise the motor sits in a pool of stagnant heat. 35,000rpm should be fine just check temps, and not over 40,000
