i wanted to post LEE's response from castle to my thread in another forum...
"Those temps sound about right. These motors are very comparable to the NEU motors. You certainly should not feel that the green ones are any less good than the black NEU motors. We truly licensed the design from Steve.
The fan on the controller is controlled by a temp sensor. The heat sink and controller are very efficient conductors of heat. The fan does not need to be on long, especially if the ambient air is at 55! That's normal."
its odd im getting responses that motor temps are too hot and some normal, hmmmm... im thinking that the neu/caslte motors run hotter than the orginal neu's but its not a factor as the motors are rated to run hot according to PDC.
the fan coming on before 150 and for a short time is normal
