11.20.2005, 11:56 PM
A new set of diff gears is only $9 or so, so for $20 and some shimming, they will last you for a while. Just check them periodically for slop(if the drive cup wobbles excessively, it is time to rebuild/re shim). Eventually, the answer will be 1/8 diffs, as I am sure you will tire of the diff building after a few times(though a newly shimmed fresh set of gears will last a while).
