12.11.2008, 10:58 AM
The reason why AC/DC chargers are limited to ~50w is efficiency really. Those have simple linear power supplies in them that put out a set voltage (usually around 12-14v). They could use supplies that put out much higher voltage, but the charger would get VERY hot charging any lower cell counts at high current (and would need a much larger heatsink), be much heavier, and cost substantially more. And, due to size/weight/component cost, currents are limited to around 5A or less.
So, they utilize a switching power supply that converts 12v DC into whatever the charger needs to put out. For 2s, it only needs to put out ~9v. For 6s, it needs to put out ~30v. The idea is to make the internal supply voltage only as high as needed to charge the battery. This minimizes losses (heat).
But why 12v DC input? Why not simply use a switching power supply that converts 120v AC? That answer: versatility. 12v DC is a common car voltage, so this allows you to use them on a car battery. Then, for the house, you can use any type of power supply you want to get 120v to 12v DC. Including a 12vDC AND a 120vAC power supply in a charger would be expensive and wasteful.
To get 12v DC from 120v AC, switching PS units will be far cheaper/lighter than a linear PS at high currents, which is why many use computer power supplies.
