Serum
Serum's Avatar
11.21.2005, 02:06 PM
Yeah, i did a bit of pilot testing on those things.. That problem is corrected though.. Daniel, you don't want the original OFNA diffs, their cups are too short to fit the CVD's (you need to use spacers on the CVD's then, the UE diffs (8spiders) are about 65 dollars a set, including all the needed bearings, pinion and ringgear.. And they are FUN to make!) make sure to order some shimms with them as well.
