12.12.2008, 01:47 PM
PROBLEMS
Hi im finishinf the build of the tekno mbx5t brushless conversion. Im installing the motor mount and the electricluthc and i noticed that the 13 teeth cluthcbell have a very slow diameter so the spring of the two shoe cluth rub the cluthbell when is spinning. So i tried another racers edge( cause the cluthc bell of the tekno kit its a racers edge one i think) clutch bell and the same happend, again the spring rub the cluthc bell (i tried with two clutchs, a mip one and the stock one from the kit). So I installed the stock revo clutch bell, a 15 teeth one and now the cluthc bell spins free and smooth, but when i install all the motor mount with the motor, clutch bell, etc... I noticed that the flywheel rubs on the brake pad. So what i have to do now? install a bigger clutch bell, that will fuck my gear ratio since a 13 clutch bell is reccomended.
I hope you understand what i mean, if you dont i will post some pics. Maybe i have something installed bad but i dont think so. My motor mount is a 44mm.
Thanks for all and greetings
