speedracer1129
12.13.2008, 10:31 AM
Originally Posted by BL Dreamer View Post
This was a interesting thread to say the least. Sorry about the motor thing it sux I know....anyway about the above comment by Takedown, what and where are these "records" that we are talking about. I just want to do some research. BTW someone mentioned that foams were not allowed but produced higher speeds? Where do I get foams precut/trimmed true. I myself am after some high speeds as well and I am new to 1/8 scale brushess. Any schooling would be helpful. I will start a thread when I get all my shipments in, but we are working on putting together the order in the "brushless" thread.
We need more pics and vids when you get up and running. Please keep us posted on the progress.
BTW the reason I asked about the record was b/c this is the vid that got me into the 1/8 scale buggies for BL.
http://www.youtube.com/watch?v=GKctWzmIgVc
And it sure does not look like he's running 10's or 12's. Any info on this set-up would enlighten me.
Just wanted to say hello and wish you more luck on your project.
Have a good one,
Paul
Thanks Paul!! Ok, here goes..........
First, here are some links for "high speed records"
http://fastestrc.blogspot.com/
http://www.rc-isc.com/
Next, about the foams...... Everyone is trying to follow the ROSSA rules setup by the guys in the UK who came with them so everyone can have a standard to go by. For MT you can not use foams because they are not tall enough. I believe the class says the tires need to be at least 5.5 inches, not sure. When you surf the above sites, you will find the correct info.
Lastly, your inspiration is quite an ingenious system!! That buggy is running on 4S. HOWEVER.........................his trick is that he custom mounted a Savage 3 speed tranny to basically create an "overdrive" to the spur gear creating more rpm than if it were to be connected directly to the diff. Thus creating higher rpm and a higher top end. I definately take my hat off to that guy!! He was thinking WAYYYYYY out of the box!!
Good Luck!
