12.13.2008, 07:38 PM
Lazy goit.
Google will explain the 'how', or most retailers will have some info too- try JRH's website as he is a key source in that department.
Where is taken care of by simply looking around- most aero websites sell outrunners, as does JRH again, and google is your friend once again.
Mounting is simple- L shaped bracket (a little common snese ansd iniative goes along way, as does a vice and hacksaw).
How to use them- very tricky, you have to get it right first time as typcially cant adjust the gearing, you have to know exactly what voltage you will use and factor that in with the kv rating to arrive at a desired speed.
The search button will yield the projects that use them- its called research, its how you explore the forum and disciver amazing things (as opposed to just expecting poeple to list everything you want to see and know).
it would be very nice to have it all spoon fed to one's self, without having to do any research or figuring things out for one's self, but the long and short of it is- if you dont know how, then research the answer (Linc and Sike are the outrunner dudes, do a search of their threads and that will turn up a wealth of info).
