starscream
RC-Monster TQ
starscream's Avatar
12.13.2008, 11:17 PM
I've seen them- I wouldnt trust them as far as I could poop them out my butt.
You need solid solder joints made with good quality solder; the solderless tubes seem to use liquid paste inbetween the cells to make the electrical connections... big thumbs down on that idea.
It's just a guess but I'd think youd have a hard time passing these packs out your backside. However, I don't know you so maybe you have a freakish Sphincter.
It is obvious however that you're naive about this topic. For one, you absolutley do NOT need a solder joint for a "good" electrical connection. Second, these cells have aluminum ends which seem virtually impossible to solder together unless "you" can poop a spot welder out your butt as well.
In conclusion, your opinion is noted but however dismissed due to apparent ignorance.
Ha Ha
