12.14.2008, 04:27 PM
yea if you got mikes new hardcase lipo then youd have a better lipo..... it alos makes a BIG differnce on how you broke in the 12t and do you use BUSHING lube, not bearing oil or lube but bushing specific lube, also spray the comm with motor spary as much as possible before and after every run it good, and if you want an even more advantage put a little dry ice on the motor about 3 mins before your race and itll just about freeze the motor and youd be amazed at how much faster an ice cold brushed motor runs..... that not a joke either the dry ice trick works wonders.
