dangerwr
12.14.2008, 09:09 PM
Originally Posted by ssspconcepts View Post
5S with a 2200kv Neu can easily be geared for 60+ mph...especially with this rig because it is very light and it will be a road car.
The EL8 RCPD top plate is nice but I recommend you get the one for the Jammin because I had to drill out the mounting holes quite a bit before everything would line up perfectly. I finished the mount by using some flanged spacers/washers so it would look nice and tidy.
Gotcha. I will pick up the top plate for the Jammin' buggy. How light is the car compared to a 1/8th buggy? Also, it seems that you knew to upgrade the diffs--will the stock ones not hold up very long under BL?
