Originally Posted by dangerwr
Gotcha. I will pick up the top plate for the Jammin' buggy. How light is the car compared to a 1/8th buggy? Also, it seems that you knew to upgrade the diffs--will the stock ones not hold up very long under BL?
The stock diffs were plenty robust...I had a spare set of the spiders. I figured I'd use the spiders since I had them handy and they are smoother than the stockers. Not exactly sure, but the car is probably 10-15% lighter than the Jammin buggy-IMO. It is considerably lighter than my BL Jammin CRT, which is set up with the same conversion stuff.
