12.14.2008, 11:58 PM
As for crawling: Yeah, might not be the best crawler ESC in BL mode, but may work a lot better in brushed mode. Also, I have all my ESCs set for low start power and at least 50% punch control, so that may have something to do with it. The purpose of the test was to compare the starting algorithms, and if you see my original post from wayyy back, you can see it changed quite a bit.
