12.15.2008, 07:05 PM
Also, check your frame rate setting. The AUX channel does not work in the 5.5ms setting. You must use 11ms or 16.5ms. If you are using cheaper analog servos (such as the 645MG) go with the 16.5, 11ms can sometimes cause glitches and inconsistent response.
