George16
Supermaxx
George16's Avatar
12.18.2008, 11:38 AM
Originally Posted by jordan... View Post
Hey guys,
i got my cvd back tonight. My mate turned down a 12.9 hardened steel bolt on the lathe to fit perfectly. For some reason the 3mm pin i had didn't fit, it was too small, i think it ended up being like 3.1mm or 3.2mm i needed, makes a big difference. I also got done trimming the F-150 body to fit the truck. Hopefully the temps stay cool with that on, but i think im going to have to cut a hole in the windscreen evenutally. Taking it out for a run tomorrow, hopefully the batteries perform a little better on their second charge.
replacement pin
Oh, and notice anyting missing on the truck?
cheers
jordan
I replied to your post in the traxxas forum regarding the pin. I had used 1/8" through-hardened ejector pin left over after making my hinge pins. 1/8" = 3.175mm.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
