Thread: lipo and 9xl
MetalMan
MetalMan's Avatar
11.21.2005, 11:18 PM
40amps cont. should be plenty for that motor. But 3s Lipo isn't enough voltage. You need 4s absolute minimum. I would consider 5s to be the minimum for usable purposes!
The lower C rate cells won't deliver the same voltage that the higher C rate ones will. Plain and simple, that is the main difference.
