Andrew32
12.19.2008, 04:49 PM
Originally Posted by cobra198 View Post
Thats a good question - I havent even touched on batteries yet! As I said, im new to the whole electric thing (let alone the world of brushless lipo) and am just tryin to take it one step at a time. I guess I should decide on that soon so I can figure out my gearing etc.
I am looking for decent speed, but i dont need anything that is too insane. Ive seen some vids of people's builds flipping on there lids constantly - that is a bit overkill for my application. I would like a setup that will run consistantly with the motor and ESC, but be punchy enough to tear up some dirt tracks and jumps.
Any suggestions for a good but not too over the top/ expensive battery that will mesh well with the MMM combo with the 2200kv motor?
Edit: Just submitted and saw the edits you made to your post! I am guessing that the prices will vary greatly, and I really need to check out my options. Im not even sure what would be considered a middle to upper-middle class battery for this setup. Time to go check out those companies you listed! And of course, any other suggestions or expertise with batteries is always appreciated!
Thanks again!
Im not too sure on battery voltage selection as im not sure what your vehicles gearing is...but i do have an opinion
4s- Drivable, probably see mid 40s and good temps. People call it the "sweet spot"
5s - I think still drivable but you are gonna start stressing the drive line. Probably see 50's. Temps will be pushed but should be ok
6s - IS INSANE. would be a bit much. youll see 60's but you wont be able to do anything but go in a straight line. Start breaking weak parts, flip over all
the time. You need to watch temps
As for battery Brands
Thunder power and flight power are considered top. They have been around a long time and are used by alot of the plane and heli guys (they been doing lipo for a long time)
Neu IMHO is the middle class battery. Wont break the bank but i see them as quality packs
Zippys are the cheapest batteries out there that i would trust. Little to no bad reviews on them.
Maxamps - over priced, over rated cells. And yes i do own a set of maxamps and they are starting to fail. Cant get 15 minutes out a 6000MAH battery.
Charger
If your doing a 4s, get one 4s pack. One pack is better than 2 IMHO
same for 6s
I recommend the hyperion chargers. They are expensive but have built in balancers and I LOVE MINE
Check Out monster mikes page. Hes got the 3 popular hyperion chargers.
http://www.rc-monster.com/chargers.php
