Thread
HB GT10 / LS10 Mods Upgrades Alternate Parts
13
Gee
A Horse's Ass
12.21.2008, 04:00 PM
Finally got around to painting the new body for my LS10. When went to install the stock body mounts I found the post were broken off and were too low to work with the body. So this is something that I came up with that works with the body I painted. May not work for you body but it might help spark and idea of something that will work.
For the front I used and older emaxx shock tower and cut in half. Then attached it to the LS10s front tower with the existing holes. Found some post and tightened them down it it.
For the rear I used the rustlers tower and cut a section out of it. Lined it up withth the holes on the rear tower for the LS10 Then I sandwiched it between the wing mount and shock tower. The body I have will work using just a single mount in the rear.
Gee
Find all posts by Gee
