12.21.2008, 04:51 PM
You most likely have the esc programmed to your radio incorrectly. Reprogram the esc to the radio and make sure the green light is coming on when you are going forwards. If the red light is on you need to reverse your throttle channel, resetup the radio to the esc and possibly swap 2 of the motor wires to get it going forward with forward throttle and the green light on.
