Gee
A Horse's Ass
Gee's Avatar
12.22.2008, 12:44 AM
Finally found (or took) the time to do a little organizing and cleaning up. Didn't want to burn the daylight during the summmer. Snow on the ground and I've been wanting to share my laundry room with you all. There's a lot in a little space and I ended up with way to many pictures. It's taken a lot of time just to pick which ones and then try and combine them. It great that Magman started this thread. It not often that when you show your workspace to visitors that they "get it". You know what I mean. Some of these picture are like a collage. To save taking up a whole page of this thread.
One thing you might gather from this is that I like to see everything. The cabnet and drawer really don't have anything useful in them, Everything is out in the open.
This has been on my to do list since early summer.
Here's the cart. This is where it all started. It use to be a old dot matrix printer stand from work. I started adding crap to it after I got my second RC the pede. It's got a few amenities, can put tools on each end one has a peg board the other has and magnetic strip. Has drill holders up front so I don't have to lay them on the table. Because it usually has crap all over it. It's on a platform with wheels so I can move it around easily. Has three differnt spots for the rcs to sit on. The office has a raised floor and these were floor jacks that have a top part that slides down onto the bottom section. I made some custom cutouts for the different rcs to sit on. You can just pick up the top part and put it on the base portion of your choice. They can spin around freely for easy access to what ever. It also can be a pain at times so you can also lock them down with a thumb bolt. The top of the cart has a grove routed along the edget to catch the nuts and bolts and there are holes drilled through it to put hex drivers in. The center is made out of acrylic so the light shine up through it. If I need a flat area on it I can just pull the section out and flip it over. The lights were the latest addition. It seemed like no matter where I would stand I was still blocking the light. Old eyes maybe. I need to add a support piece to it. Looks like the big fellows could use a diet. Behind it is my laundry room. There rest of this should be so long winded..
Here a collage of the cart and how the jacks work.
Here looking into the room from the back door,
Here the steel rack converted into a paint stall.
Rc paints and the gears/transmission area. Working on the gears and transmissions is about the only time I like to sit down.
Here's a the dremmel collage. Made the storage case for bits and stuff out of old tape backup cases. Visual thing. I could see what was there. The other spinning rack at one time held large kitchen utensiles. It was drafted to do a more important job. Got the craftsman dremmel hanging on a swing out.
In the lower right hand corner or the dremmel picture. Those are the BEST damn screw extractors I have ever used. I stumbled on them at a General Store in town and they were the last ones they had. Under 20.00 they have not failed to get a screw out for me yet.
Shock workstation and and old VCR storage rack. Also drafted for more important duties.
The corner...
Battery charging area and canned paints, stains, etc. In the upper right hand corner I made a rack to for some cordless tools. Only really heavy tools in the wood shop for long term.
