Originally Posted by BL_RV0
Especially if you get a hacker without a flat spot. And if your wife asks, say you're having trouble with your new hardened shaft!
Wow, ladies and gentlemen, his name is Ian, and he will be here all night (drum roll)
I generally use the bench grinder to produce a flat area, so material is not really a concern. The harder steel does take a few passes to get to the desired depth...
