12.22.2008, 01:37 AM
Looks good Chris. Not sure but the front steering link looks a bit low... Maybe you need a set of clockable c hubs to increase the caster towards neg. Or just move the lower links forward on the chassis one hole to bring the pinion down and rotate the steering up a bit. May help with your approach angle. Or get the ckrc behind the axle steering kit, less than 20 bucks...
I do like the axial axles, I have them on the jkeeper truck I made. I run a lower pinion angle, so my steering is not really in the way. My ground clearance looks to be less than yours, so my driveshafts are almost level. They never bind, no matter what.
