Unsullied_Spy
Unsullied_Spy's Avatar
12.23.2008, 02:40 AM
so how do they run?
All I can say for my 80mm is
Turned all 4 40 series tires on my Muggy into pizza cutters, worked a screw in the the steering spindle loose, launched it into the mini bar making an epic THWACK, and popped a dogbone out This was with a 2000KV motor on 4s maxcramps lipos
Originally Posted by q8-maxx View Post
The bad thing is there a holes in the back :(
Got 'em in the front, too. Avoid mud and clean the dirt out when they get dirty and it should be fine.
EDIT: One thing I'm shocked to see are the wires...They are the same diameter as the ones on my 50mm! I can't understand how those things can handle the power these can put out. The ones on my Neu are considerably larger and never got hot under extreme use.
