squeeforever
squeeforever's Avatar
11.23.2005, 01:13 AM
Originally posted by Serum
You can not run a 4 pole plettenberg with any bk controller. it is some kind of timing problem that can't/needs to be fixed.. Who needs plettenbergs when there are 2240's and 50's...?
i asked mike a while back if the plettys would work with the warriors and i was told that it should work but the rpm limit would be cut in half. the reason i asked was because of something i saw on the instructions (that make no sense).
