Single speed tranny w/ lexan cover and motor mount.
Gee
A Horse's Ass
Gee's Avatar
Single speed tranny w/ lexan cover and motor mount. - 12.25.2008, 07:05 PM
Here a quick run down of what I did when I was making a single speed 3906 tranny with a lexan cover. The LEDs were an after thought. The pictures will tell most of the story. If you have any questions let me know. Here's my "Gee1" single speed transmission - the prototype. Prototype leaves a larger grey area. Doesn't it?
Well, I got distracted while I was replacing a shaft in the 3906 transmission. I've had the notion to do this for a while. This time something said to do it now. I was going to take the 3/8" lexan and try and make a motor mount that the front of the motor was inset into it. So the pinion didn't need to be so far out on the end of the shaft while using a the revo slipper. Still need to look into doing that.
I had a chunk of 3/8" lexan that I could maybe get two of them out off. The motor mount was made out of 1/4" lexan. I copied the mount I had by tracing it out from my G1 on the evo. No creativity there. The 1/4" lexan has some flex to it so I will need to rethink the motor mount or use a thicker piece of lexan. The flex might be fixed with a different design.
The pictures are not in order really but they are close and show the work that was done.
I started first with the output gear holes. I say holes because I drilled the hole for the shaft and a hole for the bearing to sit in. I found the 12x15 bearing fit just right on the enlarged part of the output shaft. I used a Fostner bit that was the closet to the 15mm size hole I needed. If your not familiar with Fostner bits. They leave a flat bottom to the hole you drill. I then use the dremell to enlage the hole to fit the bearings. If your not familiar with a dremell you need to get out more. LOL Once I was satisified with the output shaft. I then drilled the holes for the input shaft. Doing the output shaft hole first then drilling the second input shaft hole with the case as a template (using a dowel and couple of scews to anchore the output shaft to the case) gave me better odds of the two shafts being aligned straight and hopefull not bind when the gears were installed. The input shaft hole was done like the output hole was. Except I didn't need to drill the hole all the way through the lexan. No harm done. The end of the shaft rides in a bearing there. Is not as watertight as a frogs butt. It's gonna get the job done though. I used the 5x11 bearing for the end of the shaft to sit in.
The input shaft took two 5x11x4 bearing to get a good fit. The output shaft used two 12x15x4 bearings. In the end I needed about four shims to get a snug fit for the output shaft.
After I did the first two holes. I worked on getting what ever was sitting above the 1/2 case to sit flush with (or slightly below) the lip of the half case. I removed the top half of the idler gear post and a sanded it down a little. For the dog drive to sit flush. I drilled a small indent slightly smaller then the nut I had holding it and the second gear. I took a screw and put in into the nut from the topside of the nut and tapped the nut into the recess I just drilled for it. I used a 3x12 screw to secure the to parts together. Then with the nut and scew recessed into both gears. I went to hacking away at the dog drive carrier. Cut the two lips off it (back one mainly to be able to see the teeth on the output gear) and then sanded the outside that would face the lexan down.
A side note on the above. On the two cases there is a small lip on each to provide a tigheter seal. I removed the seal on the case I was working with with the dremel. I suppose it could be called the male. I am still debating if that was a good idea. One pro is more of an area for the lexan to sit down on. Con was more work was needed to get everything to sit below the half case line. Problem that with either way is still getting a real good seal. I might try to use the dremel to carve the female part into the lexan when the new case arrives. Will need to practice carving other wise the cover may look like lines in someones palm.
Alright, snow plow just made a pass by the house. Can take an RC out now.
Everything fit really well after my initial two holes and some sanding of gears and posts. Well enough that no shims were needed and the gears spun freely and smooth. That wasn't good enough, the more I tried to make it "better", the more shims I neede in the end. I eventually stopped trying to improve it.
Next I cut out the pattern of the case in the lexan and then trimmed it up with the dremel. I almost cut the pattern out before doing the two holes which I think would of created some problems with the cases edges sitting flush, gears not aligning up right, screw holes off, and a hangover. A little sanding around the edged and then used the dremel router to round off the edge.
Then the LED light idea came into play. Tried it with red and blue. To me the red looked meaner, more evil. The blue was more cool, smarter. Ended up blue, they were alread soldered and in place. I already solder three up before his set becuase I connected them wrong. It also got tiresome taking the cover off, shimming, cover back on, cover back off, so on and so on. I tried carving a groove for the wires to sit down in. To hide them a little better. If I used just the black wire with a black case it would not stand out as much. The groove ran over the top of the case. Needs some more work for it to be easier on the eyes and hide the wires a little better. I can't hide them under a lexan motor mount.
I lightened the midtones up in some of these pictures with it installed in the emaxx. Not so the keen eyes of my fellow RCMers would see I installed the transmission backward or see that I tried to fix it by installing the tires backwards. JK on the tires. That's for better traction in the snow that's on the ground. I lightened them so you could see the emaxx a little it was installed in. When I was removing the tranny to put it in the right way. I thought I would experiment with some reflective aliminum tape. Those are the parting shots for now. I still have some work to do on it. It works just fine. The work is more for appearance and tighter seal around the case then functionality. I have another case on order to play with.
Let's go play in the snow!
