Thread: Might need help
12.26.2008, 12:47 AM
Ok, you may need to use thicker diff fluid in the center, or at least check to make sure you have enough in there.
As for the deans, shorten up the wires going to the esc and the battery, and make sure you have good solid solder joints on the plug. And clean the plug too, dirty plugs are bad, mm'kay.
