12.26.2008, 02:43 AM
Originally Posted by SnoopMaxx View Post
Was the REVO style slipper a direct fit ?
Or did you have to modify it ?
You have to use a revo (nitro) input shaft, and either drill a new hole for the top gear, or drill a new hole for the pin that hold the slipper hub. It will only work with the single speed cause the revo input shaft is not long enough to mount both gears from the emaxx. Good mod, as the stock slipper sucks...
