12.26.2008, 12:42 PM
Better to use an external bec like the ccbec with the mm on 3s. It will cut the heat produced by the internal bec and give you selectable voltage too. Just remove the red wire from the mm rec wire. I found the extra caps are only necessary when running 4s, but the bec will cut temps alot.
