sikeston34m
sikeston34m's Avatar
12.27.2008, 12:33 AM
Originally Posted by asheck View Post
With my Medusa 2000,MMM,geared 24/58 in an Erevo it takes around 1000-1300mah,of my 4000mah 6s 25c hecell lipos,to go 1.42 miles.Thats doing nothing but speed runs. With speeds of 55+ Free Image Hosting at www.picturetrail.com
Is that the Medusa heat sink? It looks like a good one and I'm sure it really helps keep the motor temps in check.
I'm using a Novak heat sink. The Black Bulky type, but it really works good. I run the whole charge out on 4S and I can barely detect any heat with my fingers. Just a tad warmer on 5S with 40 to 50 degree temps outside. The Fan on the Monster isn't even coming on.
Your gearing is a 2.83 pinion/spur ratio. Where mine is a 2.88 ratio. Cool.
Last edited by sikeston34m; 12.27.2008 at 12:15 PM. Reason: Corrected posted gear ratio
