12.27.2008, 02:32 AM
Originally Posted by Unsullied_Spy View Post
That's very nice! Have you looked into getting RPM arms for it? Those look like the same arms my Muggy came with stock, and they broke pretty easily. The RPM arms come sized for the LST/Aftershock and need their adapter kit (plastic washers) to fit the LST2/Muggy. Also, the stock turnbuckles (on the RPM arms) are pretty weak so you'll want to upgrade to Lunsford turnbuckles as well but once you've got all that they're really tough.
I had a look at the lst arms from rpm and really do not like the shims needed to adapt them to the lst2 hubs. I will stick with the arms I have, and maybe upgrade when/if they cause me issues. I will most likely redesign the mounting to eliminate the spacers if I do go with the rpm arms....
Thanks for the lunsford tip!
