Unsullied_Spy
Unsullied_Spy's Avatar
12.27.2008, 02:51 AM
I had a look at the lst arms from rpm and really do not like the shims needed to adapt them to the lst2 hubs. I will stick with the arms I have, and maybe upgrade when/if they cause me issues. I will most likely redesign the mounting to eliminate the spacers if I do go with the rpm arms....
Thanks for the lunsford tip!
I wasn't much a fan of the adapters at first, but after breaking my 2nd pair of arms I said screw it and bit the bullet ($100+ for the arms, adapters, and turnbuckles ).
No prob, I sheared a turnbuckle off after about 1-2 minutes after putting the new arms on and I had to trim down the plastic in order to extract the remaining bit of turnbuckle
