Thread: Outrunner CRT.5
BL-Power
BL-Power's Avatar
12.27.2008, 12:15 PM
Update after 3 months:
After around 40 runs with the Quark, fire came out in early November. So i shipped it to the adress in Korea that was printed on the box of the ESC. Online tracking showed me that they received it on November 17th. Since then i heard nothing from Sky&Technology, my emails are just not answered. So i'll never buy a Quark product again.
I replaced it with a Sidewinder with UBEC and it's really the best Outrunner ESC i've ever tested. It has a smoother startup than a Kontronik Jazz 80, a Mamba Max and a Quark Competition 80 with capacitors attached. After 2 battery packs, it's never warmer then 120f.
When i had destroyed the gears of my Hitec 225 the third time, i decided to replace it by a low-profile servo. First i tried the HXT9612 but it was even to weak to turn the wheels when they weren't touching the ground. I'm sure it has not more than 1.5kg of torque although it should have 5.4kg. Now i'm using a Bluebird high speed servo, it has metal gears and found it for 30€ at my hobby shop. I've mounted it using Traxxas 4-Tec servo mounts. It works nice and is really fast.
The RTR weight of my CRT.5 with Jato Wheels is now only 1840g, thats 4.06 lbs. I'm now very happy with it and I can't find anything i could improve.
Here are some pics for you: http://picasaweb.google.de/Brushless...NorCRT5Setup3#
@ Semi Pro: I found the motor mount at my hobby shop, they had it there for 1.50€
@ Burnsi: The runtime is about 13min - 17min.
If you find anything really useful i could improve, please let me know.
 Send a message via ICQ to BL-Power
