12.28.2008, 05:43 AM
Ok, thanks again. I'm just wondering if the 4350mah 5s would give me the same run time as the 6000mah 4s if I gear down two teeth on the pinion.
The 15 tooth on 4s is good, but could use just a little more top end and a slightly cooler temp.
