Originally Posted by E-Revonut
It has been talked about on here in the last couple days. your True RC Lipos may not be up to the task, you may wind up destroying them. IMHO that is not a 6s setup. That motor IMO is best suited to 4s use, 6s if you wanted to do some speed runs. 6s on my 1515 2.5d (1650kv) was insane so I dropped to 5s. Do some reading around on here but this is what I have seen in the last couple days.
I agree with the 6s/2.5d match ...I had this on a converted Revo I used to have, the 1515/1y has a higher amp draw that unless you have a good set of 25c lipos will eventually become a problem. When you run a higher voltage/lower kv setup you can get away with lower quality batteries. The motor will draw a certain amount of wattage and the more voltage you use the less amps you will need ( amps = heat).....volts x amps = watts
