sikeston34m
sikeston34m's Avatar
12.29.2008, 12:00 AM
Ok, looking back at your problem... Not sure why the cells are dying, where did you get them?
Also that esc is poor, but a MMM and run 5s lipo with your current motor, or go up to 6s lipo and drop down to a 520kv motor. Either way you get to buy some stuff... Some 30c flightpower cells would be nice, like the 3200mah packs for 6s. Not sure what the weight difference would be though.
I'm with Linc on this one. Alot of your problem is your ESC.
The startup routines very from ESC to ESC and they are not created equal.
Quark does pretty good, but I think Castle has them beat even with starting an outrunner under a load like a direct drive setup does.
